Cracked 5.0 Head - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2013, 02:17 PM
Cracked 5.0 Head
I recently discovered an issue with the intake valve on my #8 cylinder.
I brought the head to a local shop this morning. It looked like an easy fix until he found there was a crack on the head between the intake and exhaust valves.
Is this common? What would cause it?
Old 04-15-2013, 05:20 PM
BOBCRMAN@aol.com's Avatar
Common. Caused by heat. GM thin castings. Something is causing that cylinder to run hot or the vehicle has been overheated in the past.
Crack usually starts at exhaust seat and migrates to intake seat, spark plug or the nearest coolant transfer hole. Intake valve burns because it can't dissapate heat due to cracked seat.
Cracked Head Leaking Head Gasket? skippy89 Engine 36 03-12-2013 09:03 PM
cracked head or head gasket???? onebadmerc Engine 12 12-04-2008 01:10 PM
cracked head.. :( Artemis Entreri Engine 6 10-08-2006 09:42 PM
Cracked head 87442lover Engine 19 01-18-2005 02:08 AM
Cracked head deez_nutz Engine 11 01-23-2004 09:37 PM
