cracked block - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2006, 05:34 AM
cracked block
i need help with a cracked block that had froze up. had to replace the intake manifold. bo jb weld really work? Any information would help or products.
Old 03-21-2006, 06:11 AM
bondo's Avatar
It depends on Where the Cracks Are...........
Waterjacket to the Outside air,...... Go ahead,+ JB weld it........
If it's Cracked between the Waterjacket,+ the Oil cavities,.......
It's Junk.........
Old 03-21-2006, 06:32 AM
cracked block
when i putt the antifreeze in and then the water i got half of the water in it stared leaking out the front of the block, right below the spark plugs a little. i have to take a certain part of i don't know te name of the part. it has 3 tubes on it a longer tube that goes on down under the car. i need help i can call you to ask you a few questions if that would be fine. i need a number thank you for your help
Old 03-21-2006, 07:15 AM
bondo's Avatar
OK,.....
It's leaking, Just Below the Sparkplug,.??....And, Behind the Exhaust Manifold,..???.....
That would be The Very Top of the Block,.... Probably right at the block's side to Deck point.........
IF that's the case,......
Your motor is JUNK.......
A Crack that far Up on the block is going to allow the Deck(or the Top of the Block) to be Unstable,......
The Tighter the Headbolts are, The Bigger the Crack will get......
I'm Sorry,.... There just Ain't No Fixing a block cracked in That Area.......
The Only Fix,......... Is Block Replacement.........
If it had been Lower on the block,.. down by the Coreplugs,... You Might have Saved it.......
I'm Surprized that you Didn't find several Cracks in the Lifter Valley when you replaced the Intake Manifold.......
Old 03-21-2006, 08:24 AM
help
the crack is just below theoil filter on the block. so is that the head or is it junk
Old 03-21-2006, 08:25 AM
Originally Posted by kenneth29
the crack is just below the oil filter on the block. so is that the head or is it junk
i know i can relace the head for about $185.00
Old 03-21-2006, 08:33 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Before we get to far lost,
What engine are we working on here?
Old 03-21-2006, 08:35 AM
cracked block
92 tarus wagon 3.0 v6
Old 03-21-2006, 08:55 AM
Aluminum block or cast iron?
Old 03-21-2006, 08:59 AM
cracked block
factory engine is all i know
cracked block kenneth29 Engine 8 03-22-2006 10:54 AM
i need a better 400 sbc block 406 ss monte Engine 5 06-21-2004 11:31 AM
Big Block/Small Block - Ford BigBlockBabe Engine 12 11-10-2002 04:01 PM
Block Painting do's and dont's Maverick Engine 20 11-02-2002 08:50 AM
