cracked block can a block be welded - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2009, 06:50 PM
chevy bb 572's Avatar
CHEVY BIG BLOCK 572
Last journal entry: sum rides i got
left a block outside with water in it over winter cracked by freeze plug go figure my bad will post picks later can it be welded?
Old 06-16-2009, 06:57 PM
Cape Cod Bob's Avatar
Serch on here and you will find lots of answers. In short, yes. Depends where the crack is. And how well the welder knows his business.
Old 06-16-2009, 07:13 PM
S10 Racer's Avatar
http://www.warsprints.com
IMO, unless it's an expensive aftermarket block it's not worth taking a chance on welding it. I would look for another good core.
Old 06-16-2009, 10:17 PM
Bummer Dude, what block? I did that once to an engine, I kept the two pieces from the side as souvenirs. Sad part is was all fresh and still in the garage never made it down the road Like said about a new block as you only know about the crack you see. What if into the cylinder wall or other area? You could probably pick one up at a boneyard and make do.
Old 06-16-2009, 11:14 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Welding anything cast is a tricky thing. For practical purposes concerning stopping a leak, yes a block can be welded. For the purpose of repairing a block for good, no it can't be welded.
Please post the engine and other applicable things. We can't really answer your question intelligently. If you're talking about a small block chevy, then absolutely not... blocks are free on the internet every day. If you're talking about a rare early ferrari block that will only run as long as it takes to get on and off the trailer, then you can repair it with chewing gum.
Old 06-16-2009, 11:16 PM
Bub's Daddy?
400 sbc starter problems, Cracked Block. Adapter kit needed? tiresmoke55 Engine 7 04-16-2011 03:28 AM
hv big block pump for small block roy383ci Engine 9 05-24-2006 06:52 AM
409 Block with a cracked Water Jacket 62ImpalaSS Engine 1 04-20-2006 12:15 PM
cracked block kenneth29 Engine 8 03-22-2006 10:54 AM
cracked block kenneth29 Engine 9 03-21-2006 08:59 AM
