Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cracked block or cracked heads
Old 01-18-2012, 02:58 PM
bondo's Avatar
bondo bondo is offline
Originally Posted by 4x4Chevy
I just called the machinist I had do my valve job and he said that he did magnaflux my heads and they checked out good... I dont know if that strengthens the thought of a cracked block? Anymore ideas??
Ayuh,... Drain the block, 'n cooling system,...
Pressurize it with 'bout 15psi, 'n Listen.....
You'll hear the air escaping, follow the sound....
