Cracked cylinder, bad head gasket or ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2012, 04:39 PM
Anglia_Nut's Avatar
I had an Australian 351C long block built in California ( I'll reserve the companies name until I get to the bootom of this problem) I did the normal break in every thing seemed fine and then after about 200 miles I noticed a little smoke out of the drivers side exhaust. This slowly got worse. When the engine is cold, no smoke but as it comes up to temp here comes the mosquito fogger. I replaced the head gaskets, Had the head pressure tested, no cracks, no leaks. I'm actually convinced that I have both burning oil and coolant coming out of the exhaust. I have no sign of coolant in the oil and a coolant combustion leak test was inconclusive. Do you think it's possible to have a cracked cylinder that could allow both oil and coolant into the combustion chamber? I'm at a loss as to what else it might be. Any ideas would be appreciated.
Old 12-17-2012, 05:00 PM
I would think that it's possable for a cracked cylinder to allow coolant in through the crack, as well as allow oil to slip past the rings. Or mabe a cracked ring, coupled with a bad head gasket.
When you had the heads off, what did the bores look like?
Old 12-17-2012, 06:01 PM
I would be looking at the intake gaskets for sure. I had one that was losing coolant. No visible leaks. No water in the oil. Dexcool did it in. Wasn't burning oil, but the way the gasket was deteriorating it was possible that it would have in time by way of the lifter valley. Not saying thats what it is for sure, but it may be worth a look.
FWIW, Good Luck,
ssmonty
Old 12-18-2012, 06:59 AM
Anglia_Nut's Avatar
Thanks for the replys. I thought I might have had an intake gasket problem too but I've changed them twice with no change. When I had the heads off I looked at the bores pretty close. I didn't see anything other than some nice cross hatching. I ordered a leak down tester so maybe I'll be able to determine where it's leaking.
froze cylinder<<<<<< cracked head lt1 Seanj Engine 2 01-20-2010 04:06 PM
diagnosing cracked head/gasket engine tear down 1960chevyapache Engine 2 04-17-2009 09:33 PM
SBC 305 cracked head, blown gasket or? 35oldstruck Engine 6 11-02-2008 06:10 PM
cylinder head cracked?!?!?!?! Blob Engine 4 01-24-2005 06:12 PM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 10:08 PM
