cracked fiberglass ground effects - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2002, 04:47 PM
Post cracked fiberglass ground effects
whats the best way to repair cracks in aftermarket fiberglass ground effects?
Old 11-19-2002, 07:23 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Depends on how big the crack is, some can be repaired, some can't. Just sand through the gel coat and put a layer of cloth and resin over small cracks. Big cracks you just use more resin and cloth or matt. Sand it smooth, use a good sealer and paint. Pretty simple process, just alot of work involved.
HK
Old 11-19-2002, 08:16 PM
banned
Post
yeah it is simlilar to making your own fiberglass piece except you are just filling in the missing area
Old 11-19-2002, 08:42 PM
dinger's Avatar
Post
The Jan. 2003 issue of Street Rodder has a good step by step article on fiberglass repair. (this months issue, just got it)
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
