Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cracked Head Leaking Head Gasket?
  #23 (permalink)
Old 02-19-2013, 09:50 PM
Northern Chevy Northern Chevy is offline
When you do pull the thermostat and have another new one on hand, you can heat up some water on the stove and while its on the stove hang both stats into the water by some wire and compare their action and how far they open as that usually tells the story if one is bad and doesn't open near as far for the same heat being applied. Just make sure you keep track of which is the new one and which was the old one !.
