Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cracked Head Leaking Head Gasket?
  #35 (permalink)
Old 03-09-2013, 06:40 PM
skippy89's Avatar
skippy89 skippy89 is offline
Alrighty guys, I have the vacuum results in. At start up I read 18 lbs with rapid shaking, then it started to fluctuate between 16 and 18 lbs for a few minutes before deciding to drop to 14 lbs and fluctuate at a steady rate between 14 and 16. That reading isn't at my worst idle, I still had the fluctuating idle, but it was no where near as nasty as it gets in the mornings. My vacuum results pointed to late ignition timing, which confuses me because my timing was dead on, before I started having these problems.
