Cracked T350 case again - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2006, 07:37 AM
For the second time I've cracked the case of a turbo 350 trans in my car. The first time was doing hard launches at the strip. The second time with a different T350 it happened just bipping the throttle going around a corner.It's behind a 500hp 383 chevy , Hughes convertor that flashes to 3800rpm in a big heavy 70 Monte Carlo. Whats the solution? A Turbo 400 maybe a mid-mount engine plate , indexing the trans/ engine centerline? Suggestions please. By the way these are proffesionally rebuilt transmissions.
Old 07-10-2006, 08:03 AM
Old Yeller 1970's Avatar
Loud Pipes Save Lives
I had a friend with a 600hp 468 '70 SS Chevell who kept having the same problem. He went with a trany from TCI and never had any more trouble.
http://www.tciauto.com/
Old 07-10-2006, 12:09 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
By chance are you using solid motor mounts and rubber or urathane on the trans.?
Old 07-10-2006, 01:00 PM
Polyurethane mounts . Energy suspensions.
Old 07-10-2006, 01:07 PM
Oops sorry. Polyurethane all the way around , engine and trans.
Old 07-10-2006, 01:10 PM
nitro_baller4692's Avatar
floppers forever
Jw Ultra Bell Part #92452
Old 07-10-2006, 07:11 PM
fast68's Avatar
likes chevy trucks & boobies
only thing i could think is driveline alignment
but if everything is for sure lined up good and straight then i dunno
interesting
Old 07-10-2006, 08:31 PM
spankys rod shop's Avatar
Cracked 350
If both trannies are cracked across the top, just about where the"bellhousing" area reaches its smallest point near the pump , then yes you might check the trans index to eng. centerline, and your dowell depth and locations. you might need offset dowell pins to corect mis-alaignment.
Old 07-11-2006, 06:16 AM
Yep , thats the crack.
Old 07-11-2006, 06:53 AM
I had the same type of crack in my Nova. I found that the trans case was touching the trans tunnel in the floor. I lowered the trans mount a quarter inch and had the case welded. Problem solved.
Bob
Small frame (case) GM alternator donor cars ken47 Electrical 3 05-01-2006 10:01 PM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 10:08 PM
700r4 cracked case stuartc Electrical 6 12-02-2004 10:56 AM
Cracked case? 72elcamino Transmission - Rearend 4 09-04-2004 07:31 PM
new tranny case? Tissue Transmission - Rearend 11 04-27-2004 07:52 AM
