cracked tranny case - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2009, 04:52 PM
63 Fairlane
cracked tranny case
i am working with an aluminum trans housing and a steel pan. The front ear on the trans right where a bolt goes is cracked. I managed to re-tap the bolt hole hole to a larger size without doing any further damage, as the existing bolt was stripped. the pan is finally snug and the bolt is tight, but fluid continues to leak on the top side of where the bolt comes through. Aside from removing the entire front of the car (97 Altima) to gain access to tig the housing, does anyone have any ideas on how to seal this thing up. I tried some jb weld type stuff, but either I did not have the work area clean enough or it just did not work as it still leak like all... h e double hockey sticks.
Thanks!!!!!!
Old 01-13-2009, 06:50 PM
sprecher48's Avatar
Oddo nut
Last wiki edit: VW engine basics
Last journal entry: note from the sandpit vol.#3
Location: sunny south(maybe rainy,haven't looked outside today) florida
Wiki Edits: 10
re;oh he double hockey sticks
drain the tranny, clean the mating surfaces meticuliously!!! Make sure the steel pan is not warped at that point,put in a new cork gasket and at the place it's leaking put a good sized bead of high-temp silicone;tighten it to snug and let it cure for 24-48 hours.then tighten it to spec. it should do the job.good luck!! tomj
Old 01-14-2009, 10:26 AM
dinger's Avatar
Good advice Sprech.
Good to see you back, everything going ok?
Dan
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 01-14-2009, 02:26 PM
63 Fairlane
clean, dried and applied...hope it works. thanks...will let ya know. JB
89 Astro van tranny problems, rebuild help questions searay Transmission - Rearend 14 05-31-2008 04:26 PM
Tranny to cross member alignment issue Blue67Camaro Transmission - Rearend 5 01-14-2008 01:24 PM
!993 T-Bird Tranny Re-build Mike in Canada Transmission - Rearend 8 06-29-2007 07:09 PM
2004R tranny sotxpanrider Transmission - Rearend 0 05-20-2006 08:49 PM
Tranny update/Torque converter question RObs71Nova Transmission - Rearend 5 12-16-2004 09:37 AM
