cracks in nosepiece - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2002, 09:58 AM
New Member
Post cracks in nosepiece
on my 78 formula the plastic nose piece has little cracks in it. what is the best thing i can do to fill these little cracks in the plastic? should i use bondo or some other filling or some sort?
Old 12-29-2002, 12:57 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Sand off all paint and primer down to the yellow urethane plastic, go to your local auto parts store and get the special flexible urethane front end filler. Its about $25 for two tubes(parts A+B) mix it put on a thin coat sand smooth and it should fill all the little spiderwebs. Remember when repainting to use flex additive in your paint on these style noses and tails unless of course your preticular paint is flexible enough, ask your paint guy when purchasing.
HK
