I bought both the Craftsman DA sander and 100lb Capacity Sandblaster. I lost the paperwork/instructions on both. Today I finally had a chance to get out in the shop and work on some bodywork, and tried both tools and was thourghly disapointed with both. I am hoping that someone can tell me how to configure either one or both to get some performance out of the tools. I know the max PSI for both but past that I am clueless! Thanks!
Is this what you have? And what specifically do you need to know about them? It could be your compressor is too small for the equipment or your airline is too small for the equipment or a combo of both. What size of airhose do you have and what size of compressor? Any pics of the equipment?
IMO- those two items are notrious for eating cfms. Add a small die grinder and the compressor will NEVER shut off. They SAY 4cfm for the DA, but 14 is more like it! I always have to wait for the compressor to catch up. Mine is an Ingersol Rand 80 gal 14cfm @90psi unit, and its too small!
Yes both of those are the same tools I have, sorry for not clarifying that. I have a upright oiled 25 gallon husky with an output of 5.8cfm at 90 psi. I am unsure of the size of hose. Same as what has always come with my compressors (hoses are all covered paint so I cant find markings). My question is, are there some setting or variable that I am missing that would make these tools useful? The DA is decent but I honestly think I would be better off hand blocking it. I still have the box and it says it is adjustable per job but dont have the instructions on how to do this. On the Sandblaster I dont know if i was just expecting to much but it was absolutley pathetic, I tried all diffrent angles and depths of spraying and found it to only take off a tiny area about a 1/4" at a time and not get through the old paint after for a very very long time. I tried all three diffrent sizze nozzles and went higher and lower on the air pressure all to no avail! I bought these tools thinking it would speed up my bodywork process, so far it has slowed me down and cost me $$. Any Ideas?
your compressor is way too small, I have yet to use a compressor that can keep up with any type of sandblaster, except for the large trailer type that power jackhammers. on the DA the adjustment is the small black nob above the disk, centered is for the most speed and either way off center will slow it down. The best tool I use for stripping is a large 7"/9" angle grinder fitted with a soft rubber backing and a very aggresive sandpaper, works really fast.
Go look at about any Compressor none of them recommend that small of a compressor for any of the sanders. Hell alot of the 60 gallon compressors barely fall under the "useable" category with them.
I have that Sears sandblaster. It works but as others have said, it requires a LOT of air. Also, they are notorious for "bridging" the sand in the bin (and thus running out of media at the gun tip). I have to shake or knock on the side of the bin every couple of minutes to insure a continuous flow of sand. The bridging gets even worse if your sand/media gets a little damp.
I finally sprung for a blasting cabinet so I only use my Sears for big stuff now that that won't fit in the cabinet unit.
I have a similar size compressor and it will barely keep up with a DA, I have to "rest" it when using the in-line sander. It could never run a sandblaster.
That said, it's very practical for the small jobs I do at home. Big ones go to a friend's shop.
I just stripped an entire door with $8 liquid paint stripper and a $35 palm sander (80 grit 1/4 sheet) in about 40 minutes. That includes the 15 minutes required to let the stripper activate. I got this at Ace Hardware. I will highly recommend this. Use an old rag and pair of gloves to apply the stripper in one direction wait 15 min. and use a wide putty blade to take it off.
I think I could do the whole car for about $32. Make sure you wash it good. Pros say it can hide in cracks and attack your new paint if your not careful.
I have also tried the Aircraft stripper in the rattle can and it did not work as well as this stuff.
Allright once again my ignorance bite me in a uncomfortable place. I should have known the DA would suck out the air I just assumed (that was stupid I know) that my new compressor should easily push it. My air file (strait line ?) sander seems to do ok with the new compressor. Is there any type of DA or jitterbug or anything similar that would be good on curves and the like for bodywork that arent air hogs? Thanks for your help
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
