Craftsman Drill Bits
I'm looking to get a set of decent drill bits. Sears has a sale on Titanium and also Cobalt drill bit sets. Looking to hear opinions on these as well as recommendations for sets from other suppliers (like Dewalt or?)
Thanks |
Made in the USA ?
More and more items are made off shore and their quality sucks, The first thing to do is see where they were made.
You might check out the Norseman bits, I have a set and they have held up pretty well.
http://www.norsemandrill.com/Catalog_Index.html |
To be perfectly honest, I do not like Chinese products....but Sears and Craftsman in particular seem to be insisting on quality from their offshore manufacturer. I unknowingly bought some Craftsman tools that were made in China and they are fine.
Vince |
It would depend on what you were using them for. If you are just using them for general grunt work, and not thinking about sharpening them, they should do you fine. If you use them on a regular basis and like to keep a keen edge on all your bits, I would look for something else. The titanium and cobalt is just in the coating.
I have a set of Milwaukee's that I had for over 35 years and have supplimented these with general use bits from Craftsman, Chinese, etc.but my complete index of bits for 'good' use, is the Milwaukee's. If you are doing drilling in 1/4" and under material, go for the multi- bit with four or five different sizes in one. |
You can always take a look in the McMaster Carr web catalog. Most of the drill bits that I've bought from them in the past have been US made - but of course, that can change :pain:
http://www.mcmaster.com/#metalworkin...d-rods/=4at19m Dave W |
My friend bought some imported bits that would not break. They bent! That is a sign of quality. :eek:
It sure is, but what KIND of quality? :pain: |
I have bought quite a few Craftsman bits and unless quality has slipped recently they are hard to beat for the cost. Certainly there are better bits and it just depends on how much you want to spend and what you intend to do with them but for general all-around use Craftsman bits work just fine. TiN (Titanium) bits work really good and are cost effective for general use with Cobalt being more costly but better suited to drilling hardened steels and abrasive metals like cast iron.
I have sears bits and dewalt and both have been good to me but i do like the dewalt better though, But either are fine IMO. ....Cole
What about just buying a regular set of black oxide along with a Drill Doctor and sharpen as needed??
That's exactly what I do - the Drill Doctor does a great job but they are a bit tricky to use and get the right 'heel' angle
In other threads, I've coined the term; Cheap Chinese Communist Conscripted Child Cruelty Conflicting Capitalism Cr*p. The 9C's.
You can specify the level of quality you want when dealing with the Chinese or most any other offshore vendors. Where things fall apart is when American companies merely have existing Chinese products repackaged under their name with regard more for the bottom line than quality. If only the Chinese would use the same poor quality in their own nuclear weapons program. They'd blow themselves up. Yipee! I think Ti coated drills from China have more to do with perception than quality. Ti coatings are designed improve tool life in a controlled setting. The only real way to make the Ti coating cost effective is to run the drill in a CNC Mill where feeds and speeds can be acutately controlled. This can't be done with the average drill press or hand-held drill. I guessing Ti coated 9C drills are pretty much the same quality as the uncoated drills and have been Ti coated for profitabllity, not endurance. |
[QUOTE=Old Rotor Flap]
I think Ti coated drills from China have more to do with perception than quality. Ti coatings are designed improve tool life in a controlled setting. The only real way to make the Ti coating cost effective is to run the drill in a CNC Mill where feeds and speeds can be acutately controlled. This can't be done with the average drill press or hand-held drill. [QUOTE] Also those CNC drill bits are continually flooded with cooling/cutting fluid which we traditionally do not employ in our hobby. Vince |
I never bother with cobalt or titanium coated bits. I like the jobber length HSS, 118% drill bits. Easy to sharpen by hand, or smaller ones (3/16" or less) are cheap enough to toss. The only time I pay for premium split points is for drilling thinner gauge stainless.
| All times are GMT -6. The time now is 09:06 PM. |
