craftsman jack - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2012, 10:33 AM
craftsman jack
My son has a craftsman 950239 aluminum jack. The shaft that opens and closes the valve just spins it will not close the valve. Is there a fix for this, thanks
Old 03-18-2012, 02:25 PM
327NUT's Avatar
A couple of things, did you take the jack apart to try and diagnose the problem yourself?....did you look at the owners manual for trouble shooting?....did you google "craftsman 950239" and read the PDF comments on the jack, the parts catagory and diagram?
Once you figure out what's wrong with it you can purchase the correct parts to fix it. The problem is sometimes the parts and or parts AND labor to fix it costs more than a new Arcan jack at Costco.
Old 03-18-2012, 02:47 PM
Irelands child's Avatar
Craftsman jacks are really starting to get a name as junk - mine went to the dump a while back - it went up, then often came back down - and at the worst possible time with no help from me.
If it's out of warranty, I agree, it will probably cost more to fix then it's worth
Irelands child
Old 03-18-2012, 05:18 PM
There is no diagram, and I can't figure out how remove the shaft that operates the up down valve.
Old 03-19-2012, 08:16 AM
S10xGN's Avatar
Gotta love a turbo!
If it's the same (junk) jack I had, there's no rebuild parts for it, only a complete cylinder assembly.
Russ
Old 07-08-2012, 07:47 PM
The company that manufactured this jack is SFA. The release valve for your unit is not available. They do have a complete hydraulic unit. If you are interested, contact me.
Marc
Craftsman Metrinch Dave E Shank Garage - Tools 7 02-07-2011 06:36 PM
Torin Black Jack 3-Ton Floor Jack and Stands adamsautoadvice Garage - Tools 11 01-21-2011 11:21 AM
The future of Craftsman tools. crazy larry Hotrodders' Lounge 42 01-20-2008 08:19 AM
Craftsman powdercoating gun Quadzilla(EFI) Body - Exterior 1 12-18-2005 07:15 AM
Craftsman DA Sander & Sandblaster 70chevy Garage - Tools 10 12-28-2004 09:51 PM
