Crane Cam...Have grind # but cant find it anywhere.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2006, 07:24 PM
I just snagged a built 350 off a guy. It has forged rods, pistons, crank. He said it had a roller cam but didnt know the specs. (Older guy that is putting different engine in his Vette and didnt want solid lifter cam) He didnt want to bother with having to change the cam out and various other things. I am cleaning the engine up and painting it and replacing parts as I need to.
I pulled the cam out because Im gonna clean up the intake manifold and while I had that out I thought I would see what grind was on it and see if I could find the specs. Not sure if I want to run this cam yet.
The grind on the cam is FHI-294-2-NC, Crane, 11-19-89. Now it is a solid lifter cam. Thats about all I know. I cannot find the specs anywhere.
If anyone could help me out with this that would be great.
Old 05-15-2006, 08:19 PM
NorthStar's Avatar
Ok I found it. I knew these old catalogs would be good for something.
294/304 solid lifter, rpm range 3800-7200
intake 248 @ .050, .520 lift
exhaust 258 @ .050, .540 lift
114 lobe separation
lash .010 / .012
Old 05-15-2006, 08:20 PM
Awesome! That is one serious cam...Had no idea it was that aggressive. Not so sure Im gonna use it...
Thanks a bunch! I have an old catalog but I couldnt find the darn thing.
Old 05-15-2006, 09:50 PM
GoneNova/406's Avatar
i have had that problem before and just called crane or what ever manufacturer it is and have the cam on hand at the time.they will tell you what to look for and give you all the info.no mistakes this way.you can try email but i never had any luck with that.price of a phone call is all it cost.
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
So we degreed our Camshaft last night.... Malibu73 Engine 48 10-31-2005 07:45 AM
Progress on 37 Ford Coupe DarellGLewis Hotrodders' Lounge 28 08-31-2005 07:27 PM
305 cam carb manifold stickshift Engine 6 04-12-2005 03:46 PM
Cam for '85 HO 305? Mike_82 Engine 11 11-22-2004 08:06 PM
