Crane Cam ID Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2009, 10:53 AM
Crane Cam ID Help
I am typing to identify a cam has two numbers stamped on the end: 119516 and 961710. The grinded number is 118521. Now this last number 118521 is listed with Crane, but as a grind number instead of a stamped part number. Anyone that can help, I would greatly appreciate it. I am thinking the cam was bought early to mid 1990's.
Old 04-12-2009, 02:27 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
I can find nothing on the first two numbers, but here's the timing card on 118521.....It's a mechanical roller for a SBC....ground on a 112 degree Lobe Separation Angle.....
http://cranecams.com/?show=browsePar...tType=camshaft
Old 04-13-2009, 07:05 PM
Thank you sir. That would make sense then, pulled it out of the car with mechanical lifters also. I appreciate the help.
Glenn
Old 05-11-2009, 08:02 AM
big block cam
crane camnumbers on cam 139576-8e1a stamped on cam wanted get new springs lifters brought short block no info on cam specs any help would be appreciated
old crane cam catalogs Sleeve396 Engine 19 12-25-2010 07:59 PM
will this cam work well? STLrocker Engine 11 03-29-2009 08:39 PM
Cam break-in and zinc Frisco Engine 34 03-13-2007 08:22 PM
383 Rod & Cam clearance crusherdbuzz Engine 9 11-12-2006 06:17 PM
274 crane cam 78 chevy truck Engine 8 03-17-2004 04:46 PM
