Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Crane HI-6 Ignition with a Duraspark distributor
Old 02-01-2010, 04:48 PM
boris_thespider's Avatar
boris_thespider boris_thespider is offline
I'm building my first car and I'm trying to sort out some wiring issues. I have a Crane Cams HI-6 ignition system and I've got a Duraspark distributor. Here's part of a technical bulletin I found from Crane Cams:
"There are three wires that come out of the factory distributor - orange, violet and black. Use the orange (+) and violet (-) wires as your signal wires and hook up to the mag trigger side of the HI-6. Leave the black wire alone as it is not used."
I'm attaching a screen shot of my HI-6 wiring diagram. If someone could tell me where to cut and splice I'd be eternally grateful
Mike
Name:	HI-6 Installation.jpg
