Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Crane HI-6 Ignition with a Duraspark distributor
Old 02-08-2010, 11:28 AM
matt167 matt167 is offline
Wiki Edits: 31
you will want to contact crane on that 1.. the trigger connector has 12v going to it, which the DS distributor wouldn't need. then it would need just the white and a ground but I'm not sure
