Crane HI-6 Ignition Wiring Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2010, 07:43 AM
boris_thespider's Avatar
The instructions for my HI-6 ignition box show the main power for the unit going directly to the battery. I was wondering if I can I run it through my ignition switch so it only gets power when the key is on. I was concerned if there would be a constant power draw from the battery even when the car is off. Thanks...
Mike
Old 01-12-2010, 11:49 AM
That is a pretty big wire to try to put through the ign switch. Just wire it per instructions it wont draw any current until the other ign switch wire is cut on.
Mike
Old 01-12-2010, 12:14 PM
Thanks for the quick info
Ignition Question 1957chevyrod Electrical 0 10-03-2008 11:12 AM
General Ignition System Question ourmartyr Electrical 1 03-06-2008 04:57 PM
Redneck-rigged VSS wiring question for 700R4 Mad Maggot Transmission - Rearend 1 02-21-2006 09:49 AM
1969 Camaro HEI ignition location Question Izzy17ri Engine 1 12-08-2005 05:38 PM
Painless wiring harness question Big Geek Electrical 9 02-28-2005 04:30 PM
