The simplest fix would be to use a coil with 3-4 ohms primary resistance, if you can find one.
Pertronix makes a nice conversion too. The Pertronix coils for the conversion come with a ballast resistor. Maybe use one from them if the resistance value is the same as stock. It might be a bit better quality. You could use resistor wire for the positive side of the coil. No ceramic ballast to clutter things up. Larry |
When you read the directions it does get a bit confusing. I'm using a Crane XR-i conversion on my 1974 Corvette 350 engine and am using a Crane PS91 performance coil. The XR-i paper work says; if you go to a performance coil and have a ballast resistor or resistance wire keep it and if you had an internal ballast coil add a 1.2 - 1.9 ohm ballast resistor. Now the water gets Muddy!! I also used a Crane PS91 performance coil. Its directions say; the coil can be used as is with most electronic ignitions and most aftermarket ignition systems. But if your running points you must use a 1.2 - 1.9 ohm ballast resistor. So... This is from Crane paper work??? (XR-i) Electronic dist/performance coil = add a Ballast resistor... (PS91) Performance coil/electronic dist = No ballast resistor. I'm running the XR-i and a PS91 coil streight up with no ballast resistor (i cut the resistance wire out) and a MSD6AL unit on my 1974 Corvette 350 and it all seems to run great. I got a headache from the directions, you might give Mallory tech a call.
Hi Pony,
Thanks for your reply. I am glad to hear I am not the only one who confused over the XR-i instructions. I will call their tech line to see if they can shed some light on the subject. Maybe we can even get them to improve their information so other don't have to go through the same confusion. Thanks Ken |
I would follow the directions with which ever system you are going to use.
Troy
