crank bearing play? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2002, 09:29 AM
New Member
Post crank bearing play?
I have a v6 4.3,when I turn crank over by hand
there is play before pistons move,is that normal or should everything move at once with out play.
by that I mean I can wiggle crank clock/counter clock wise before pistons move
Old 11-14-2002, 10:39 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
If there is play at the bearing, you have big problems or have missized bearings.
chris
Old 11-14-2002, 11:03 AM
SAE Member, ASE Master Cert.
Post
If you are referring to piston movement at top dead center, then yes the crank will move SLIGHTLY before the piston moves. This is because the piston "dwells" at TDC for a few degrees as the crank changes direction. This dwell time is affected by the length of the connecting rod, as an engine with long rods will have more piston dwell at TDC and less dwell at BDC. However, at any point other than TDC, your piston should move with the crank, otherwise you have some real serious bearing or wrist pin problems.
Old 11-14-2002, 05:51 PM
Post
are your heads off? what you may be feeling is slack in the timing chain.
Old 11-15-2002, 05:00 AM
New Member
Post
Thanks for the info ,to be safe Iam going to pull crank out and have it check.Ihave movement where ever piston is located.
