Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - crank casting #
Thread: crank casting #
Old 05-13-2007, 07:54 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Your crank is a 400 crank. I don`t know if that number just wasn`t used very often or whatever, but there are others out there online that have the same number on there 400 cranks. Look on the flywheel mounting flange of the crank, if it has a dowel pin I`d say the odds are better, the 400 is the only small block chevy crank I ever seen that used a dowel pin.
