Crank endplay - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2008, 05:27 PM
Crank endplay
I had a Ford 302 (stroked to 331 c.i.) built. The crank end play was at .008". After putting 400 easy miles on the engine the end play has increased to .018. We are going to pull the engine and try to determine what has caused this problem. It's a standard shift, Ford 5 speed. Any ideas on what we should look for?
Thanks, Mark
Old 10-17-2008, 06:10 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
A 'ballooning', or, not seated all of the way torque converter(automatic), or 'gunk' on the input shaft in a standard trans application.
In 'automatic' transmission applications, a 'crimped', or restricted cooler line can cause this also.
I am led to believe it is an automatic trans application, because it happened in so few miles.
'Rule of thumb' with torque converters, is when installing them you should not be able to get your fingers between it and the bell housing when installed correctly. (all the way seated in)
Been there and done that, years ago.
I know the 'pain'.
Old 10-17-2008, 07:15 PM
Thanks, Mark
1) Improperly crank finished thrust surface by manufacturer. This has been a sizable problem with some manufacturers.
2) Set up not done to align the upper an lower halves during engine build up.
It is important to be sure that the thrust surface of the upper and lower halves meet flush.
a) This is first a dry installation to see how they look without the crank. This includes pulling the cap bolts to torque. Also check to see that the cap does not tip toward the front or rear or side to side in the transverse plane when it's bedded into the block.
b) When the crank is laid in; the mains except for the thrust are pulled to torque. A pry is used to shuttle the crank back and forth two or three times with the thrust main installed with light bolt force to insure that the upper and lower halves join without a step between them. Then the mains are torqued up. The idea is to eliminate any offset between the lower and upper surface because if a step is present it will wipe the lubrication off with failure not far behind. During this phase also check for clearance.
Bogie
327 forged crank #4672 62CHEVYC10 Engine 2 11-19-2006 04:18 PM
267 crank into 350 block 74chevyflat Engine 6 08-26-2006 01:15 AM
Repairing a damaged crank by welding.. Old School Nut Engine 7 05-10-2006 08:05 AM
forged crank question Ratoflic Engine 2 04-18-2006 04:50 AM
engine rebuild query re; crank rotation.. crazy larry Engine 9 08-04-2003 02:03 PM
