crank to flywheel mate - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2005, 09:49 PM
I am trying to find the correct flywheel for a pontiac 400 68 goat with a borg warner t10 and crank # 496452 I need the correct flywheel which i dont have . does anyone know? thanks Keith
Old 10-18-2005, 02:06 PM
As the Moderator of the General area.I moved this to the engine section...where it will be viewed by more folks who may have the answer.
DEUCE......
Serious problems removing harmonic balancer! spyderdude Engine 55 06-09-2005 10:01 AM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
Flywheel Inertia BillyShope Suspension - Brakes - Steering 3 09-02-2004 06:44 PM
Flywheel balancing? nomis30 Engine 3 11-25-2003 11:03 PM
STARTER AND FLYWHEEL DOESN'T MATCH UP mrmonte2323 Engine 8 11-19-2002 06:37 PM
