Crank, Iron or steel??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2005, 12:34 PM
WB72's Avatar
New Member
What are the criteria to determoine when to go with a forged crank? I would hate to over spend when not needed, but I also would hate it if I didn't go with a stronger crank, and end up with a mangled engine.
I want to build a +/- 400HP 450 ft/lb Small block 383ci.
Old 11-29-2005, 01:03 PM
66 T-Bird's Avatar
~Low Budget Baby~
i've heard that a cast crank should be able to hold like 500hp-550hp and a forged crank holds like 800 so i'm not sure you would need a forged crank i'm not positive on this though because i'm a ford fe fan (don't get me wrong i wouldn't be a ford fe fan if i didn't have one lol i like the mopars but they R 2 expensive and rare to hotrod)
Old 11-29-2005, 01:32 PM
302 Z28's Avatar
There are plenty of 400hp+ 383's running around with cast cranks. Forged is nice if you can secure one for a decent price, or happen to know of one sitting in a friends garage, but a cast crank in good shape can support some very respectable HP.
Vince
Old 11-29-2005, 02:40 PM
bigbadbowtie's Avatar
Bottle Fed
The cast steel cranks produced by scat/eagle are pretty decent pieces and are rated at 500+ HP. I have seen them take some serious abuse and quite a bit more than 500 Hp in a small block. They can be had for way less than 1/2 the cost of a forged steel unit. Prices on ebay for a for scat or eagle range in the 130 to 180 range.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
whats the big deal with cast steel? 406 ss monte Engine 19 02-13-2005 10:31 AM
Cast steel or Forged Crank????? brainsboy Engine 14 02-20-2004 09:53 AM
400 327 crank limey Engine 8 09-24-2002 08:53 AM
