crank key fitment - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2004, 01:07 PM
blndweasel's Avatar
paints everything flat black
Last journal entry: September 2005 - Current
crank key fitment
Hey everyone,
Ran into an interesting situation I'd never seen before...
I purchased a Mr. Gasket crank key (short style) for my 350 chevy crank (Eagle, 4340 forged)
When I place the key in the slot, it sits very loose in the slot. I tapped on it with a plastic hammer, but it still falls out.
Did I need to use a long style crank key or something?
Can I just loctite the key in there, or just leave it loose, cause when i install the cam gear and balancer, there's not really any way for those keys to come out, right?
What do you guys think?
thanks in advance
the blonde weasel
San Diego, CA
Old 07-08-2004, 06:09 PM
docvette's Avatar
Wiki Edits: 12
Key
[color=orange]Doc here
Go to your local Ace Hardware, or Home Depot and pick up the right key for it.... Is that Keyway Tapered? or just straight?
I wouldn't install it without it even if :"it Would Never fall out in a Million Years..."
My Murphy Calendar Runs in millennium's... ya know?
Doc
[/color]
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-08-2004, 07:16 PM
4 Jaw Chuck's Avatar
Sounds like you got the wrong key, it should be a tap fit or at least snug in the slot.
She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself.
Han Solo
Old 07-09-2004, 09:51 AM
blndweasel's Avatar
Isn't a millennium 1000 years?
Anyways, I'll try the long style key and see if I get better results. Too bad summit charges me $8.95 shipping for a $2.95 part.
Thanks guys
tbw
Old 07-09-2004, 09:58 AM
The keyway is probly not correct in the crank. . very common with the offshore stuff lately. You may also want to check your damper fit, I have had many customers with dampers that just slide on. . .no press.
Chris
