-   -   Crank Photos Cast or forged (http://www.hotrodders.com/forum/crank-photos-cast-forged-226926.html)
ChevroletSS 12-07-2012 01:21 PM
3 Attachment(s)
Can you all tell me what crank this is. Cast or forged....
DoubleVision 12-07-2012 01:44 PM
I always go by, Wide parting line, it's forged.
If it's a single thin seam it's cast.
vinniekq2 12-07-2012 01:55 PM
take a picture of the throws from the end of the crank,looks cast
ChevroletSS 12-07-2012 02:17 PM
What do you mean by parting line and what is the throws
vinniekq2 12-07-2012 02:23 PM
throws are where the rods bolt on to the crank.take a picture of the snout looking towards the flywheel end about 10 to 15 degrees off center,snout to tail,long wise,endto end from the front
ap72 12-07-2012 02:35 PM
there's identification marks on them, look them up, then you know. Its that simple.
gearheadslife 12-09-2012 12:21 AM
http://img141.imageshack.us/img141/4...ingline4zi.jpg
cast
http://img210.imageshack.us/img210/6...edcrank5fn.jpg
forged
496CHEVY3100 12-09-2012 06:25 AM
The narrow casting seam means it is a cast crank as Double vision said .another sure way is take a small ball peen hamar lightly tap counterweigkt a forged steel crank will ring ,a cast crank will have a thud sound, Note : counterweight NOT the Journal
timothale 12-09-2012 06:45 AM
Billet ?
I had a Crosley Hot shot crank for a Demo when I taught in the Auto dept at the College. The hot shot was machined from a large round bar. It had counter weights on each side of the rod throws. Theoretically you can get some teeter- totter effect in a crank caused by balance weight location, but a forged crank has stronger metal structure resulting from the forging process. But the hot shots were high reving stock.
vinniekq2 12-09-2012 09:16 AM
chev ss take a picture like gearhead posted,perfect
ChevroletSS 12-10-2012 05:32 PM
Hey guys thanks for the tips and info. I figured out my crank is cast which I kinda new thats what it was but sometimes u never know with GM. The crank is in pretty good shape and I plan on reusing it. Thanks again
vinniekq2 12-10-2012 07:00 PM
If the crank is good then use it
figured it was cast by the colour
