Crank Photos Cast or forged - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2012, 01:21 PM
Can you all tell me what crank this is. Cast or forged....
ID:	69631   Click image for larger version
ID:	69632   Click image for larger version
Old 12-07-2012, 01:44 PM
DoubleVision's Avatar
I always go by, Wide parting line, it's forged.
If it's a single thin seam it's cast.
Old 12-07-2012, 01:55 PM
vinniekq2's Avatar
take a picture of the throws from the end of the crank,looks cast
Old 12-07-2012, 02:17 PM
What do you mean by parting line and what is the throws
Old 12-07-2012, 02:23 PM
vinniekq2's Avatar
throws are where the rods bolt on to the crank.take a picture of the snout looking towards the flywheel end about 10 to 15 degrees off center,snout to tail,long wise,endto end from the front
Old 12-07-2012, 02:35 PM
Banned
there's identification marks on them, look them up, then you know. Its that simple.
Old 12-09-2012, 12:21 AM
Banned
cast
forged
Old 12-09-2012, 06:25 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
The narrow casting seam means it is a cast crank as Double vision said .another sure way is take a small ball peen hamar lightly tap counterweigkt a forged steel crank will ring ,a cast crank will have a thud sound, Note : counterweight NOT the Journal
Old 12-09-2012, 06:45 AM
Wiki Edits: 27
Billet ?
I had a Crosley Hot shot crank for a Demo when I taught in the Auto dept at the College. The hot shot was machined from a large round bar. It had counter weights on each side of the rod throws. Theoretically you can get some teeter- totter effect in a crank caused by balance weight location, but a forged crank has stronger metal structure resulting from the forging process. But the hot shots were high reving stock.
Old 12-09-2012, 09:16 AM
vinniekq2's Avatar
chev ss take a picture like gearhead posted,perfect
The Following User Says Thank You to vinniekq2 For This Useful Post:
dogwater (12-11-2012)
Old 12-10-2012, 05:32 PM
Hey guys thanks for the tips and info. I figured out my crank is cast which I kinda new thats what it was but sometimes u never know with GM. The crank is in pretty good shape and I plan on reusing it. Thanks again
Old 12-10-2012, 07:00 PM
vinniekq2's Avatar
If the crank is good then use it
figured it was cast by the colour
Scat crank i.d. Cast or forged 67Mustang Al. Engine 8 07-24-2012 06:39 PM
Forged or cast crank? 31oldschool Engine 9 10-12-2009 03:42 PM
is there a visual way to tell cast from forged crank? MM in NM Engine 4 11-17-2005 08:03 PM
Cast steel or Forged Crank????? brainsboy Engine 14 02-20-2004 08:53 AM
340 crank- cast or forged? newchevyman Engine 4 10-06-2003 07:48 AM
