Crank Pilot size for 429 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2003, 03:00 PM
'67Pony's Avatar
Dancin' to Heavens Door
Hi all~
I would assume that since its one of the biggest motors Ford made it would the the larger of the two sizes.
But does anyone know for sure what the crank pilot size if for the Ford 429 Big Block? Can it very, or will it be a set size.
The motor is originally out of a 1972 Ford Thunderbird and had a C6 bolted to it. I never thought to get the size while it was apart.
Thanks
Gary
