Crank pulley bolt pattern? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2012, 02:47 AM
Hey everyone,
I have a supercharger crank pulley sitting in my garage and I'm trying to figure out what its for. There are no markings, its aluminum 9" dia 10 rib. Its a 3 bolt and approx 3.1875 oc (measured with a ruler)
Thanks
Old 01-09-2012, 08:38 AM
68NovaSS's Avatar
Wiki Edits: 9
By 10 rib are you referring to the belt cogs? I have to say it's very old, or major overdrive at 9 inches diameter! Blower pulleys aren't upper/lower specific, (unless you're talking about a dampener...), you can change them to alter over/under drive ratios/boost. Today's blower pulleys have like 32 to 39 splines for the older 1/2 inch pitch, and 50 to 63 for newer style 8mm pulleys. Put up a picture.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 01-09-2012, 02:56 PM
Its actually a 8 rib, as in 8 rib serpentine belt pulley. I'm pretty sure its an aftermarket pulley for a Eaton blower. From doing an image search it looks pretty similar to some of the Kenne Bell crank pulleys.
I'm trying to figure out if the bolt pattern is for a SBC? Ford? ect??
Torque-ing a crank pulley bolt Longboard Engine 4 02-04-2010 10:09 AM
standard bolt pattern on duel pattern heads nskeeter99 Engine 1 02-15-2009 01:41 PM
Crank Pulley !! Guy Hiltz Engine 4 08-03-2008 12:00 AM
my 671 snout is too long? Blower pulley doesnt line up with crank pulley darkostoj Engine 10 01-11-2008 09:30 AM
crank pulley dadsgp Engine 1 02-04-2003 08:59 PM
