Crank Pulley / Harmonic Balancer - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2003, 03:21 PM
HELP!
I am replacing timing gears/timing chain on a 72 chevy covette, 350.
I am trying to remove the crank pulley and have removed the 3 small bolts holding it in place. The pulley does not seem to want to come off. I tried using a puller, but I dont want to force it too much for fear of breaking it. My question is... does the center bolt have a role in retaining the crank pulleys on the shaft? Or should I go ahead and pull-pull with the puller before removing the crank bolt?
At this time I am leaning towards removing the crank bolt to see what happens, hopefully freeing the pulley, reinstalling the bolt to bring the engine to TDC, then removing the harmonic balancer. Or should remove the balancer before going to TDC?
Thanks in advance!
-Rick
North Carolina
Old 09-01-2003, 03:25 PM
you have to remove the crank bolt anyways, I think that hold the pully down to. if it still doesnt come off you can just pull the ballencer and pully off at the same time and take it to somebody to look at it if its really a problem.
Old 09-01-2003, 05:33 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Ditto with jackflash. With the crank bolt removed use a good puller, if it sticks tap the end of the puller with a brass hammer and re-tighten as it come off.
Luv the smell of NITRO in the morning.
