Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Crank Question ?
Old 10-19-2008, 08:41 AM
chevy350_Camd's Avatar
chevy350_Camd chevy350_Camd is offline
VROOOM !!!!!!
Last journal entry: This is the Rough Draft of the V8 Frame
Crank Question ?
Hi,
Heres whats up, I recently got a block from a guy that looked liked it was in good shape, it had no upper ring on the top of the cylinder but the mains were snapped in half and ground down till they they were razors, So I wanted to use a crank that came out of A 350
(and the newly gotten block is a 350 bore and medium size journal) the motor that I took the crank out of was rebuilt 5 years ago but it sat for about 2 and only has 10000 miles on it so I figured I could put that crank in the recieved block and use the rods and pistons that came with it but I didnt know If it needs to be balanced with the different rods and pistons.
