Crank Register Loose - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2008, 07:45 AM
GoneNova/406's Avatar
a short while back i asked if anyone knew how i could fix the problem of a not loose but also not tight fitting rear cap on my 406 scb.after having some machine work done it seems i got a machinist who did not know the difference between align honing and boring.i wanted mine honed for studs.when i got it back the rear cap would not hold the bearing in place because it had been ground so badly.i took the one off my previous block and used it since all the same parts had been in it a short time before.it was fine except for not being tight.well everyone said buy new caps or junk the block and start over.just for edfication,i got a hold of stan ray of ohio crankshaft by email and he said call him.i did,and it was as simple as using a center punch to peen along the edge of the register to tighten it up.i had seen it done once before but i can't remember where,only difference was they used a chisle.stan says it doesn't work as well and they have done hundreds of them.for anyone else who may have a similar problem
Old 01-14-2008, 07:55 AM
Jmark's Avatar
I"m glad you got it going,,,,,,,,,,,,but i'm sure your "fix" will bring on a host of responses! LOL
Mark
Old 01-14-2008, 08:38 AM
i think i said it was for edification,not so much for response.
Old 01-14-2008, 05:47 PM
I have good reasons why I didn't recommend that process in the first place. Like knurling pistons and valve guides, it's pretty OK for a stock rebuild that's used for commuting. But when the going gets competition tough, I've seen this give up.
Now admittedly there's never any guarantees with a race engine, but as the investment grows, there's more to loose than a race. If a main cap fails, it's just a pile of really expensive junk.
Bogie
Old 01-14-2008, 05:55 PM
Last journal entry: PICTURE TEST
block
I can tell you that i have fixed registers like that before. One thing you are going to find,,when you take it apart they are going to be loose again..
I have also fixed them by pushing the cap,,when you take them apart there are going to be loose again.
I have fixed them by swedging the block, when you take them apart they are going to be loose again..
See a pattern here????
You will get away with it 95% of the time... If you have the 5% engine then you will just have to live with the results...
Good luck and let us know how it works out..
Keith
Old 01-14-2008, 06:26 PM
Why doesn't anyone dowel the maincaps? I know the legend Smokey Unick said he did this to keep the caps registered and also so they wouldn't pinch inwards. A 1/4" diameter piece of drill rod or tool steel would make for strong dowels I would think...
Old 01-14-2008, 06:40 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I can see where that will initially make for a tighter cap but unless you dimple it exactly the same depth and the same area on both sides, the alignment will be off so the price you paid to have it bored/honed is money down the drain because it is no more aligned now than it was before the machine work. JMO
strocked 305 400 crank ideas???? ace29816 Engine 10 01-04-2008 06:26 PM
Repairing a damaged crank by welding.. Old School Nut Engine 7 05-10-2006 08:05 AM
forged crank question Ratoflic Engine 2 04-18-2006 04:50 AM
crank key fitment blndweasel Engine 4 07-09-2004 08:58 AM
engine rebuild query re; crank rotation.. crazy larry Engine 9 08-04-2003 02:03 PM
