Crank Regrind - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2007, 07:18 PM
350 Problems
Well i just pulled all the pistons out on my 76 350 and realized that the previous owner didnt believe in regular maintenance. The rod bearings are completely shot and the crank journals arent lookin' so great. I was planning on putting all new bearings in, but not on regrinding the crank. Does anyone have a ballpark estimate on what it would cost to regrind the journals? Also, the wrist pins seem to have a lot of resistance against the rids, the rods do not move from one piston side to the other and it looks like there might be some blueing on the pins themselves. The pistons, rods, and crank are all forged. Any suggestions?
Old 12-31-2007, 08:17 PM
MI2600's Avatar
Member# 3287
Don't know where you are. Around here a crank regrind is $60-$75.
Sounds like you other problems with those pistons.
Old 12-31-2007, 09:55 PM
Jmark's Avatar
You can probably find a "kit" with reground crank and bearings for about 150. BUT, it does sound like you may have other things to address too. Do you have a good shop close by? Might be a good idea to get a professional opinion on the rest of the engine.
Mark
Old 01-01-2008, 06:55 AM
I'm starting to wonder if maybe i should just get a stroker kit.
Old 01-01-2008, 08:11 AM
bondo's Avatar
Ayuh,........
That may not be a Bad Idea,.......
'cause it Sounds like most, or All of your present rotating assembley is probably Junk.......
Old 01-01-2008, 11:51 AM
Hippie's Avatar
Last journal entry: HEI comparison.
You might want to check your block real close too if it was that bad. I've scrapped two 350's and a 400 I pulled out of 4WD trucks because the crank moved back and forth and trashed the bearing webs and caps, a good telltale is the thrust flange on the crank and the thrust bearing flanges if they're torn up or worn thin you may have block issues as well.
Old 01-01-2008, 11:53 AM
NAIRB's Avatar
It should cost between 85.00 and a 100.00 to grind the crank.
Old 01-01-2008, 12:04 PM
topdogger's Avatar
Newskool
Last journal entry: New, Used grill arrived!
Thats exactly what I did. My rotating assembly wasn't horribly but it was pretty pad. Machining around here is REALLY expensive.
I think the quote was between 200 and 300 to grind a crank. Just to get my block cleaned, bored and checked was to be 800-1000. Balanced with some prehistoric balancer that looks like it was used on the first ford vehicles was said to start at 600.
Needless to say I got a Eagle stroker kit with forged rods, ht pistons and a new 383 crank. I've had to shop around for a lot of machining cost. My rotating assembly is being taken to a different city to a guy with a new computer balancer and a quote of 300.
Old 01-01-2008, 04:05 PM
Well the mains look fine, its just the journals. I think the 383 route is what im gonna take. How much machining to the block is needed to clearance the block?
Old 01-01-2008, 04:48 PM
topdogger's Avatar
Newskool
I'm not sure yet how much is needed for my kit. The guy I ordered my parts from here builds engines so I let him assemble the bottom end. I will be going in sometime this week hopefully.
Chevy engine doesn't fit Chevy Trans! 2000jack Engine 21 01-31-2008 10:51 AM
Crank questions tjracing85 Engine 1 04-06-2007 01:27 AM
forged crank question Ratoflic Engine 2 04-18-2006 04:50 AM
Can't figure out what crank I have Mad Maggot Engine 3 11-06-2005 09:20 PM
Serious problems removing harmonic balancer! spyderdude Engine 55 06-09-2005 10:01 AM
