If the crank is a stock 350 stroke of 3.480 then there isn`t a chance of it hitting the oil pan, if it`ll clear a stock pan it shouldn`t have any issues clearing a aftermarket pan unless the pan is for specific stroke cranks. Since oil pans are thin and if the crank makes contact it should give a hollow thumping sound. Usually a noise that`s down in that area is the timing tab making contact with the harmonic balancer so you may want to check that. Also turn the crank until you hear the noise and if the crank is making contact with the pan you should feel a slight bulge on the side of the pan.
thank u this makes sense it turns no noise then a dragging kinda sound then fine again...i know the pan is good I'm just real worried and playing it save ill have to check on this asap
First thing I would do is isolate exactly where the rub or whatever is occurring. Use a mechanics stethoscope or a length of fuel line held to your ear while someone turns the engine over by hand. This way you can see if it's coming from the timing cover, oil pan or where ever. It's not going to be the rings- your buddy isn't too keen on this one- you'd have to have something radically wrong w/the rings for there to be a noise like that associated w/them, IMHO. Also, be sure that you're not just hearing the compression escape through the intake or exhaust as the engine comes up on compression stroke. |
i think so ...hard part bought running and trying these things is that the car is 40 miles away lol...as far as i know everything should be in place and were it should be ...no spark plugs or exhaust or distributor in it yet
I had a problem like that last year, brand new rebuilt 350, where the thrust bearing goes on the crank was ground wrong , crankshaft counter weights were actually hitting the block webbing, had that motor in and out of the car three times and apart three times before i figured it out. hope this isnt the case for you. good luck with your build.
Like Cobalt says you have to try an isolate what area the sound is coming from. Front, rear, center?
Some possibilities: Is there a windage tray in your oil pan? How well does the gear drive clear the timing cover? Is the sound coming from the flywheel/flexplate if the motor is in the car already?
BSE Racing Engines |
just got it in the car witch sucks
no windage tray and if i just gessed cus i didnt have time to try and pin point it id say it sounded like it came from the pas side lower pan... gear drive was supossed to fit under stock cover i got a morosso cover so it should be clear i would think ! always the dumb crap that gets ya |
| Oil Pan leaks | my oldcar | Hotrodding Basics | 4 | 11-15-2009 07:43 AM |
| oil change- step by step instructions for women and men | Fireball | Hotrodders' Lounge | 38 | 08-30-2008 07:39 AM |
| modifying cast aluminium oil pan - questions | lowROLLERchevy | Engine | 5 | 10-02-2006 01:25 PM |
| Milodon oil pan...7 qt w/ filter or + filter? | Finmike | Engine | 6 | 07-05-2004 10:44 PM |
