Crank Shaft Seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2013, 04:06 PM
Crank Shaft Seal
Just installed rebuilt 350 in my coupe and front crank shaft seal is leaking. My question is "what is a good reliable seal and what can I do to make sure it doesn't fail again?" I have to remove complete front end of car to change and just don't want to have to do it again.
Old 06-24-2013, 04:32 PM
techinspector1's Avatar
Wiki Edits: 326
Install a repair sleeve on the damper hub....
http://www.summitracing.com/parts/fel-16202/overview/
Use a quality seal....
http://www.summitracing.com/search/d...0?keyword=seal
If the front cover is not pinned, move it around until you find the same distance from the crank snout all around the seal. (block could have been cut on the main saddle in the past, to repair a spun main. This will move the crank up in the block, no longer aligned with the front cover seal). If the cover is pinned and the seal is out of alignment, drill the pin hole(s) a little larger in the cover to allow you to move the cover around a little and align the seal with the centerline of the crank snout.
Old 06-24-2013, 06:24 PM
Thanks for your help and advise and appreciated, nothing worse than an oil leak
Transmission selector shaft seal Fab60cad Transmission - Rearend 1 10-01-2011 08:46 AM
shift shaft seal? notsure Transmission - Rearend 3 08-21-2008 04:14 AM
Shift Shaft Seal Tool nova69 Transmission - Rearend 1 02-18-2007 04:40 PM
Steering shaft seal 1939d2/s10 Suspension - Brakes - Steering 3 08-12-2006 09:25 PM
