crank shaft size. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2007, 01:05 PM
Ben.T's Avatar
F10 Builder.
crank shaft size.
I need to know the std size of a sbc one piece rear main seal rod and mains journal size. Its a 880 casting number 94-00. Also the min and max tolerances of both rod and mains. I am wondering what the min is before they have to take it 10/10. Also any info on bearing sizes will be helpful..thanks
Old 05-09-2007, 01:16 PM
re: crank shaft size
I couldn't find an "880" crank on Mortec.com, but hope this helps.
Gen.I, "Medium Journal", includes "Vortec" 305 and 350 thru '98
262...Mains-2.45"-Rods-2.10"
267...Mains-2.45"-Rods-2.10"
302...Mains-2.45"-Rods-2.10"
305...Mains-2.45"-Rods-2.10"
307...Mains-2.45"-Rods-2.10"
327...Mains-2.45"-Rods-2.10"
350...Mains-2.45"-Rods-2.10"
Different size output shaft on c4? nitrous_69stang Transmission - Rearend 3 04-17-2006 10:51 AM
Go Cart? mustangdude947 Engine 23 12-20-2005 10:02 AM
12.5 hp go kart airbag_89 Introduce Yourself 2 08-24-2004 10:22 PM
crank / block combo's toddtheodd Engine 5 03-17-2004 10:38 PM
Crank Pilot size for 429 Ford '67Pony Transmission - Rearend 0 10-01-2003 03:00 PM
