Crank shaft worth - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2007, 09:24 AM
Last journal entry: Free tires
Crank shaft worth
Just so happens a guy at the machine shop needs an stock iron Pontiac Crank for a 350, I happen to have an extra.
What would be a good barter price? I have to get my block checked for bore size and deck ht, and the heads cc'd so I can order Pistons.
No actual machine work needed yet, just numbers needed. Is this fair, low or high?
Old 05-03-2007, 01:06 PM
cab cab is offline
Given that Pontiac 350 cranks are probably almost worthless (to most folks) if you can get ANYTHING for it I think that is great....you know it is just going to sit in your garage for the next 12 years otherwise!
Most Pontiac guys (like me) will typically build a 400 or 455...I don't think you can even get forged pistons for a 350 any more unless you go custom.
Later,
Chris
Old 05-04-2007, 08:03 AM
The Pontiac crank is actually the same from 326-400 so it can be used in a lot of engines, so they aren't exactly worthless, especially if you need one, he does, and they are getting a little more scarce these days. Still lots around, just maybe not locally when you need one.
Aftermarket forged cranks go around $700 + shipping, a reworked cast stock about $200-$300 maybe, I don't really know.
I'm just trying to figure what a stock cast crank may be worth on the barter market. I'd think about $75-$150 worth of labor since all I'd be asking him to do is check all tolerances so I know where my engine is at the moment.
Can't figure out what crank I have Mad Maggot Engine 3 11-06-2005 10:20 PM
Serious problems removing harmonic balancer! spyderdude Engine 55 06-09-2005 11:01 AM
Rebuilt engine won't crank. lt1bbody Engine 10 04-22-2005 01:44 PM
Scat 9000 crank VS stock 400 crank? MOORESPEED Engine 5 03-03-2005 11:54 AM
possible to warp the crank shaft? greaser_gurl Engine 5 04-02-2003 09:48 AM
