Crank Spun Out - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2012, 08:43 AM
Crank Spun Out
I have another 350 that a guy gave to me and he said the crank is spun out. What does this mean? I can turn the engine over and the crank is all in one peice.
Old 03-09-2012, 09:41 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Being local jargon, hard telling. I'd think it spun a main bearing. Are any chewed up?
Semper Fi
Old 03-09-2012, 09:50 AM
I guess Ill unbolt the crank and if it looks good then ill use it and get new bearings
Old 03-09-2012, 10:25 AM
I guess what I would need to know is how would I tell if the crank is bad? I took it out and it looks fine. Its not craked or anything.
Old 03-09-2012, 10:45 AM
I have took alot of engines apart and put back together but yes this is my first build where I am looking for a power engine. Im looking for advise not for someone to pretty much say Im an idiot.
Old 03-09-2012, 10:56 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Nobody is calling you an idiot, but when you post that a crank might have a spun bearing, then plan to simply put new bearings on it...someone has to wake you up, you should at least know what a spun bearing's journal would look like. All but one shiny and smooth, one scored badly...what's wrong with that picture? If there's no scoring, ask the guy what he means.
Semper Fi
Old 03-09-2012, 11:04 AM
Thats was the plan. To replace the bearings and use the crank
Old 03-09-2012, 02:52 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Welp, sounds like that there krank is spun out fer sure, by gum!! Back in '42 I knew a feller . . . . .
Old 03-09-2012, 04:55 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
What they are telling you to do is take that crank to a machine shop. Unless you have an outside micrometer you will not be able to tell if the main journals are in spec. You won't know if it's cracked or not by looking at it. It would need to be magnafluxed if there was any suspiscion of cracks. The same goes for the block. Unless you have precision measuring tools you won't know if the cylinders or the mains are in spec. You could fairly easily check the deck flatness but it isn't as easy to determine the deck height. If you have the engine disassembled then it needs to go to the machine shop and let them check everything.
The same applies to the heads if you plan on reusing them.
If you put it back together with new bearings and rings and without having the necessary machine work done don't complain because you have low oil pressure, a knocking noise or it's burning oil.
What did the bearings look like when you pulled them out?
Old 03-09-2012, 05:06 PM
starnest's Avatar
elkyholic
Last journal entry: Center Link Installed
I've never heard of "crank is spun out".
I have heard of a spun bearing, generally this means the bearing has spun in the cap and saddle (either a rod or main bearing). This happens when the friction of the bearing to the crank journal exceeds the holding force of the bearing's back side to the cap and saddle (and/or the holding tabs have sheared).
In general you can tell more by inspection of the bearings than you can the crank journals. Any time the batting on the bearing surface is damaged (front or back) you need to take the block, crank, rods w/pistons to a machinist to have them checked and/or repaired. (In other words, what Fbird said).
There are instances when everything looks okay and you put it all together and find out soon after that the crank (and/or the other parts) needed to be serviced.
Now, everybody play nice.
Things aren't always what they seem.
You can't know what you don't know.
And all insults are provided with good intent, Really!
Spun bearing on 406, but why? Pre-Tuner Engine 48 05-25-2011 03:26 PM
spun rod bearing cause seandiddy Engine 2 09-11-2010 03:11 PM
spun rod bearing astrops Engine 1 04-20-2004 10:27 AM
402BB Spun Bearing Rod/Crank? bbc45473 Engine 3 02-29-2004 06:41 PM
Spun a bearing-350..Why? Ted655 Engine 17 10-17-2002 12:56 PM
