Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Crank Timing Gear - Anti-sieze??
Old 05-24-2008, 01:52 PM
dhunt00c dhunt00c is offline
I've heard you're supposed to use a little anti-seize lube when installing the balancer on the crank, but does the same apply when pressing on the timing gear onto the crank?
Also, whats the recommendation out there? Heat it up super hot or use a tool to press it on?
Many thanks!
