Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Crank Timing Gear - Anti-sieze??
Old 05-24-2008, 03:00 PM
curtis73's Avatar
curtis73 curtis73 is offline
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Not sure what engine you're building, but the timing gear should just go on without much fuss.... but either way, you DON'T want anti-seize on it. The oil will wash it off during operation and then you are purposely introducing metal flakes and other odd chemicals into your engine.
I just tap it on with a socket and a rubber mallet. Its supposed to be a .001" press fit on most engines, which means you should be able to push it on with your fingers most of the way.
