Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Crank Timing Gear - Anti-sieze??
Old 05-24-2008, 02:47 PM
curtis73's Avatar
curtis73 curtis73 is offline
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Originally Posted by dhunt00c
Really? Its a 350 SB. I had heck getting the old one off (used a puller). I've always seen guys heat it up almost red hot to get them on.
I put this one in the oven for 20 mins or so and got it pretty darn hot and still couldn't get it on.
Yeah, they get stuck on and usually require a puller to get off, but then again you can't get a mallet in behind them to take them off either.
Have you checked the keyway for obstructions? Burrs on the key? If the key isn't seated in the keyway it will never go on.
