crankcase evacuation/ventilation - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2009, 11:56 AM
anyone run the kits or make their own instead of having breathers and pcv? i currently have one breather for my fill tube on the intake, no pcv. i have fabbed aluminum valve covers to run and i want to weld in a threaded bung and run a -8an line off each cover down to the collector on each header, and just weld in a pipe on the collector and slip the other end over. anyone have pictures of how they ran theirs? thanks.
and yes, i know what happens with not running a pcv. regardless, i do not plan to run one.
Old 07-13-2009, 08:05 PM
i dont run one yet........
but my motor was dynoed with one
all i know is if you buy a kit follow the instructions to a tee!!!!
Old 07-13-2009, 11:05 PM
Will I ever get it done?
Last journal entry: Hood
I made mine for my 396 in my 60 Chevy. Got 2 A.I.R. check valves off of a Chevy (people used to give them away - got mine for free). You can buy them. http://www.oreillyauto.com/EW3/Produ...nt=735ĪtPage=0
Bought a black pipe nipple at the hardware store (probably about 6" long). Cut it in half and welded them in the collectors at a 45 deg. angle so they extended about half way into the collector and mounted the check valves to them. Bought a set of cheap Chrysler breathers.
http://www.autozone.com/autozone/cat...uestid=1205731
Heater hose between the caps and the check valves. I teed one of the hoses and ran a PCV to the intake. Really cheap and worked like a champ.
Old 02-05-2010, 05:57 PM
ema ema is offline
New Member
I didn't buy one but a friend uses this crankcase vent valve . He said it had improved its engine's has used gas excretions. But I think you can really live without it.
increased crankcase pressurization y2k600f4 Engine 8 03-11-2009 10:06 PM
Coolant in Crankcase - Got mixed with Oil leejoy Engine 4 10-28-2007 09:33 PM
Gasoline in crankcase oil Bob Norris Engine 0 07-26-2003 03:58 PM
PCV valve and crankcase breather, can you have them go open? stonedchihuahua Engine 10 05-29-2003 04:41 PM
Crankcase Ventilation 66chevy2ss Engine 20 08-18-2002 11:31 AM
