Crankcase Vac pumps on steet motor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2009, 10:55 PM
540neverdone's Avatar
Loves to spooge
How well do vacuum pump systems such as this: http://www.jegs.com/i/Aerospace/026/...K-BBC/10002/-1
work on a mainly street driven car? Idle, continued high rpm, ie freeway.
Old 06-14-2009, 08:01 AM
engineczar's Avatar
On a street car or even just a basic street/strip car you'll see no difference. Vacuum pumps really only begin to shine on engines with low drag, thin piston rings and even then the increase in HP is relatively small. By pulling a vacuum in the crankcase the amount of flutter the rings are seeing is reduced and the ability of the ring to sit flat against the bottom of the ring groove is increased thus producing a better ring seal. Also the windage of the oil in the crankcase is reduced some which slightly reduces the drag of the rotating assembly spinning in the crankcase. All that vacuum in the bottom of the engine comes at a cost though. Too much vacuum and the amount of oil getting to the wrist pins is reduced to a point where you can seize the wrist pin in the piston and from there only bad things happen.
Vacuum pumps are really only good for those with dedicated race cars looking for those last few HP.
BSE Racing Engines
Old 06-14-2009, 09:19 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
These work very good, I run them,
http://www.jegs.com/webapp/wcs/store...crankcase+evac
Luv the smell of NITRO in the morning.
Old 06-14-2009, 10:16 PM
Loves to spooge
I know it is more efficient when the engine is built to utilize the pump system. I thought as you said that too much vacuum may be harmful to a street engine.
Cam Help shsouthard Engine 18 03-29-2009 09:33 PM
Help on a Pontiac 400 dirt track motor ridlenracing Engine 9 06-16-2007 10:26 PM
Timing advance issues... autonuerotic Engine 27 11-22-2006 06:51 PM
emision loopholes digitalfrek Engine 13 03-13-2006 06:25 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
