Crankcase Ventilation for Blown Engine
I have a 350 chevy with the smaller 142 Weiand blower. The engine has been rebuilt with forged pistons, crank, etc. appropriate for a blown engine. Before I rebuilt the engine, I used to go through rear main seals more often than usual and told that the blower may be creating too much crankcase pressure. The rebuilt engine will be show quality, with many billet parts. My question is what is the best and most attractive way of relieving this pressure? Will adding additional valve cover breathers do the job, or should I consider something else? Any advice would be appreciated.
I used a filtered breather in one valve cover and a single PCV valve in the other valve cover routed to the back of the carburetor. If your rings aren't worn out you shouldn't have any issues at all.
I used two filtered breathers, one on each VC, it wasn't enough, even on a fresh motor, I finally went to a PCV system, on an 8-71 383
For some reason the forum isn't letting me edit my original post to this thread.
I noticed I forgot to mention my engine was also a 350 with a 142. trifive: I'm just curious but did you build your engine or did you get it from somebody else? I sold my K5 Blazer with that supercharger to a guy in the Navy that moved to San Diego a few years ago. I know it's a long shot but I have to ask. Last edited by Blazin72; 03-04-2011 at 07:45 PM. |
I have ran two breathers with no issues, but noticed that my oil gets black real quick. Not trying to hi-jack this thread I just have the same dilema. |
Believe it or not, I have my PCV hooked to the rear carburetor, on my blown Hemi, (engine in my Avatar) with no breather(s), and it works great. Doesn't suck oil, oil is clean, and I have no oil leaks. I figure that without breathers, the system is only pulling crankcase fumes when ever it needs to, like WOT, idleing, etc. There really isn't any overpowering vacuum while the engine is running, so sucking gaskets in hasn't been a problem...or hasn't appeared to be. Installing the PCV this way has taken care of any little seeps I ever had, and now the engine stays clean. Time will tell, but so far, it works great...
Get a crankcase evac kit...breather to header setup...it works like a charm. and you gain about 10 hp across the whole power curve. And yer not recirculatin garbage thru yer engine like a PCV system.
Thanks for all the advice. I will look into the crankcase evac system. Does this require drilling holes in both headers? Are the holes drilled below the collector?
P.S. to Blazing '72--no I rebuilt the engine--did not buy it already rebuilt. |
trifive: I replied to your PM before I read your response in this thread so disregard any redundant questions.
Not trying to hi-jack this thread I just have the same dilema.[/QUOTE] With two breathers and no PCV valve, all of the carbon from the blowby gasses stay in the crankcase and turn your oil black and is corosive also . Not a good idea. Install a PCV system to make your engine last longer and run cleaner . |
This is the kit. .http://www.summitracing.com/search/?...se%20kit&dds=1.
It is pretty easy to do. You can drill the holes or use a plasma cutter. A good muffler shop could do it for around 30-40 bucks. There is no threat of it pulling oil out of the engine...probably pulls no more than 3-4 lbs of vac. |
| crankcase evacuation/ventilation | 95dime | Engine | 3 | 02-05-2010 04:57 PM |
| Flathead crankcase ventilation | ford-merc | Engine | 2 | 07-02-2004 06:11 AM |
| Crankcase ventilation question | PrimeMover | Engine | 31 | 04-07-2003 05:26 PM |
| blown off by engine builder | bullheimer | Engine | 4 | 03-06-2003 03:19 PM |
| Crankcase Ventilation | 66chevy2ss | Engine | 20 | 08-18-2002 10:31 AM |
