cranking amps??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2008, 08:41 AM
cranking amps???
anyone know what cca battery is required for a V8 engine?
Old 05-19-2008, 09:01 AM
Wiki Edits: 31
right around 350 CA.
Old 05-19-2008, 09:19 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
As an educated guess ... 580 CCA seems to be a pretty common benchmark.
If you go to an auto parts store, ask to see their "BCI Battery Replacement Data Book"
It lists suggested BCI group and suggested minimum CCA's for virtually all applications.
A "BCI Group" is pretty much the standard way of identifying a battery's physical characteristics ... length, width, height, post style and orientation, etc
Here is a sample to illustrate
Most batteries manufacturers display the "BCI Group Number" and CA/CCA information on the battery label. Often the part number of the battery is also based on this BCI number. (i.e. P3478 translates to "Platinum series", dual terminal (top post = BCI 34, side post = BCI 78 where the case size would be the same dimensions for both of the BCI groups)
Old 05-19-2008, 09:41 AM
66GMC's Avatar
I just found Exide Batteries version of that BCI book, in a 410 page downloadable PDF file.
(Takes quite a while to download and open)
Old 05-19-2008, 12:27 PM
go to my other post titled "battery size" and you will see what I'm trying to find out
thanks
Crank Amps For A 4 Bolt 350 kdj997 Engine 11 02-20-2008 09:08 AM
Arrrgg: Car Wont Stop Cranking Over 1genbird Electrical 35 08-18-2007 09:50 PM
Strange amps light problem 78transam Electrical 8 12-04-2006 04:46 PM
No Spark While Cranking rperryman Electrical 5 06-04-2006 05:28 PM
TIG welding will's53chevy General Rodding Tech 29 12-21-2005 01:38 PM
