Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cranks/No Start Problem
Old 12-19-2004, 09:48 AM
outlaw17's Avatar
outlaw17 outlaw17 is offline
I worked on a 95 Jimmy many many times that was towed in and when it was set down we turned the key and it started , the guy would take it and a few hours later it died , sometimes it would only go 3 blocks but it started every time when at the shop , finally we just changed the fuel pump but that never did anything . One day the thing showed up and would not go and I started looking into it , I was looking for the fuel pump relay behind the glove box and when I found it and touched it I heard it click so I tried the key and whalla it started ,I shook the relay it stalled , Finally I found the problem ! Turned out to be a bad connection with one of the pins in the relay connector .
***** GO OILERS GO *****
