crankshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2006, 11:17 AM
Marcel
Last journal entry: Choo-choo town
crankshaft
Anybody know anything about a cal crank shaft, 400 for a 350 block, 2 piece seal, externally bal. thanks
Old 05-22-2006, 11:15 PM
Did you mean cat crankshaft? Haven't heard of a cal crankshaft.
Old 05-22-2006, 11:19 PM
400\350 crank
what is the basic question..there is a lot of very bright members here that i/m sure could answer any thing but your a little to vague. The 400 fits in the 350 AFTER ONLY AFTER you have it cut.. rod's & main's thus the beginning of a 383..Now if it is to be externally balanced you use the damper and the flex plate or flywheel for the 400... but if your going to have a crank cut r&m then spend a little more and have it internally balanced,then you can use all the 350 parts good luck ...jb
Old 05-23-2006, 08:10 PM
Marcel
crank shaft
It is listed as a cal crankshaft, which is brand new crankshaft made for a 350 block which is bored .030 to make a 383 ci. engine. It is made by cat ( I think it said Calf. Automotive Tools Co. That is all they had to say about it. I'd just never heard of cat or cal parts before and wanted to know if anyone had had dealing with them ( they're products) Thanks
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 08:27 AM
Damaged crankshaft snout Camaro76 Engine 8 01-07-2006 10:25 AM
4/7 cams caracer Engine 19 10-14-2005 01:15 PM
Announcing the Crankshaft Coalition Jon Hotrodders' Lounge 8 08-14-2005 05:56 PM
