The Ford 200 I6 does not need crankshaft balancing as the engine is neutral balanced.
I just recently built a 200 I6 up compleatly custom, with a Turbocharger. havn't got everything finished but the engine is built.. with your engine, being your doing a pretty much stock engine, warmed over.. your going to want a later cylinder head ( '78-'83 castings are best, D8,D9 and EOXX castings ) for the bigger valves and better flowing head. Tempo/ Taurus 2.3 HSC flat top pistions to bump the compression, shave the head .025 . this will bump the compression to 9.5:1- 10:1 depending on your final combination.... remember, the stock head gasket is a steel shim gasket .025 compressed thickness and it's no longer available, the thinnest gasket made now days is .045 compressed so that will effect your compression if you do not compensate for it. |
My turbocharger is from a 1978 Buick Regal Sport.. was from a 3.8L V6 engine... The Tempo/ Taurus 2.3 HSC flat tops are the only cast flat tops made that will fit the 200 I6, the bore is the same 3.68. my engine is .030 overbore.. you can go to www.classicinlines.com for the pistions, Mike, the owner/ operator sells split sets so you don't have to buy 2 sets of 4 to get 6 pistions. go to www.fordsix.com for more info about turbocharging a 200. I'm not the only 1 with a Turbo 200 |
tom |
For that build I would just have your local machinist make sure that all the components for each cylinder (piston, rings, rods, bearings) all end up weighing the same. Or you could get a precision scale and do it yourself but the machining will probably be less than the scale
| Crankshaft Balancing? | 66Moostang | Hotrodding Basics | 2 | 05-08-2008 11:19 AM |
| The Crankshaft Sensor! | 1988ChevyBeretta2.8 | Engine | 7 | 03-15-2007 06:05 PM |
| crankshaft balancing? | jesse01 | Engine | 3 | 05-29-2005 11:13 PM |
| Balancing crankshaft | Jimmy Neutron | Engine | 5 | 12-21-2004 06:58 AM |
