Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - crankshaft balancing?
Old 05-29-2005, 08:43 PM
Bumpstick's Avatar
Bumpstick Bumpstick is offline
Hammer and a torch
Crank, rods, pistons w/pins & even rings in some cases...? Balancer, flex plate...
But also if your going to run a high lift cam you might possibly want to do a pre-assembly and check valve clearances and consider you may have to fly cut the pistons which will change the weight also... (Do before the balance)
